aftermarket sunroof, mk2f polo
Hi all, my sunroof has the slightest of leaks and want to cure this problem straight away. I'm going to check the drainage pipes this weekend, but if their not blocked what do I do?
If a new seal is needed is it easy to make one? If not how do I source another.
Any advice will help, thanks
  • Views 984
How are you going to go about checking the drainage holes dude? I've got a leak somewhere and I want to cross the sunroof off the list!
If it's after market, chances are it won't use drain holes. They usually just sandwich the skin and roof lining ;)
Ah right :o bad times, well i will find out soon enough haha, cheers anyway
well because my sunroof is aftermarket apparently it may not have the drainage holes. But from my research there are little holes around the seal somewhere, which may have mold etc, there should also be 2 or 4 holes on the outer edge (where the excess water drains) which can also get blocked, use air to clean it or a small flexi wire (bicycle brake cable) to clean it.
hope that helps...if i figure out how to fix the aftermarket one i shall share my info :)
thanks, sam
