3-Piece split rims. From sh** to shiny
No offset stamped on but they are 16 x 7J and 16 x 8J staggered "Made in Japan" and fit 5x114 hubs.
Tyres off and they're straight as a die!
With the inner barrel out of the way I flatted the centre and began de-curbing and polishing the outer rim.
With the outer lips done, the centres painted "Ford Rosso Red" - all 3 pieces were reunited. Viola!
  • Views 1.8k
End result looks awesome, what will you be sticking these on?
What did you use to polish the outer rim?
Brilliant work mate! :)
And good choice on the centres colour!
Cheers guys ;) Outer lips were hand sanded from 80 grit to 2000 then metal-polished. Won't be seeing the road under my owership though, just doing these up to sell on!
That's a real good job fair play to you :thumbsup:
Gd Job mate, wicked transformation
