Polo 9n3 Temp Sensor Change
Is there a how to on how to change the temperature sensor on a 1.4TDI Polo 9n3 or where can i locate it?
also do i need vagcom when changing the sensor?
  • Views 1.6k
#19 is the sensor
With the engine cold, undo the cap on the resevoir to relieve any pressure in the system, then refit the cap, Pull the clip #18 out then the sensor can be pulled out from the housing, make sure you replace the "O" ring #9 when refitting, then top up the resevoir for any lost coolant.
If there was a fault code set for the sensor then you will need to connect to vagcom or a suitable code reader to delete the fault codes.
