Re-trimming plastic
Recently I tried wrapping my A pillars in faux suede, problem is I couldn't get it looking good. There's quite a large curve on the pillar and no matter what I tried I could never manage to wrap it round without having a massive wrinkle appear. Can anyone offer any advice as I'd still like to get it done :)
  • Views 955
Whenever working with plastic, heat is your best freind. Use a het gun on the faux suede, as its plastic based it should loosen, so spray on your adhesive onto the plaetiic, then stick one edge down, then hold the rest up straight, then heat the middle part, then start to stick it down a bit, then heat up again and so on. Should end up nice and smooth, And hold on beter because the glue is hot.
Hth
Hth
Thanks for that, i'll give it a go! its been annoying me for ages :(
