de badge
can anyone help me i just got a polo and want to take the badges off the boot is this a hard job ????
  • Replies 8
No
cool will give it a go at the weekend will the paint come off ?? as I've never done this before .
year? model?
y reg 1.4
I used "sticky stuff remover" think its called that.
Cover the badge in it and then gently and slowly run a credit card down the back of the badge, will leave so sticky shot on then just clean off.
Or you could use a heat gun heat it up take it ofd
Heat gun/hair dryer is the best bet because if you just pull it off may take your paint with it!
I recommend dental floss behind it then just rub the remaining foam and sticky stuff off with your finger tips.
Polish any remaining residue off with window cleaner and a microfibre cloth.
Maybe t-cut afterwards if you want to.
!m!
Boil a kettle and use a credit card
