door catch
hi I'm after some help for my 6n2 gti i have this lock
http://i169.photobucket.com/albums/u210/tj...a/polo/lock.jpg
but i got a second hand door and the wiring loom in the door doesn't have this connector on it can anyone tell me if it is meant to have a connector on it or not please as the passenger side doesn't have this type of lock
thanks
  • Views 951
Probably best to swap everything over, if you can. Not really sure what thats for tbh.
That picture is a drivers door lock, the passenger side does'nt have that connector, it's connected to the vacuum chamber in the lock and it puts either 12v or a ground to the pump unit to tell it if the door is locked or unlocked
i have swopped them but still no connector for that plug
the two driver door wiring looms i have haven't got this connector on
my problem is my key fobs will enable and disable the alarm but wont lock and unlock the car i have tried re syncing the keys like this says here http://www.carkeyhelp.co.uk/productimage.php?product_id=235
but the horn doesn't sound at all any ideas?
