afh alloy bikecarb/itb manifold
I made this for my car originally but as I'm aiming for a show car look I've made a better one from billet ally
so this is up for sale its a modified standard afh manifold with new runners welded on to match the carb spacing
it needs a little work for it to be perfect it has one or two pin hole leaks in bits of the welding from porosity in the casting but nothing some chemical metal wouldnt sort and needs the inside flowing a bit better a dremel and some more chemical metal will sort this too
making it a perfect flowing manifold for bike carbs or ITB's
lightweight and looks factory ish
the injector holes would need plugging but you the plugs could be fitted with the tap ins for the vac signal
i could sort this out for extra cost
only asking £50 for this as want it gone and it needs some work
pics
  • Views 377
What bodies would fit this Pete? I'm considering options for my setup.. (1.6 AFH)
most keihin throttle bodies will i have two similar but different sets and both fit
like newer cbr600, cbr1000, blackbird, firebird they are all generally the same spacing
may have a set of ITB's i could sell with them
and the end of the runners have the groove for the proper carb connecting rubbers or will make a better seal with silicone pipe
  • 1 year later...
i know its an old post pete but do you still have this? or fancy making another one :)
