Painting 6n2 bumper strips/mouldings
Hi all i currently have the standard black mouldings on my 6n2 i have collected together color ones in vairous colors as from my understanding these are better for painting than the standard textured black ones.
I wanted to ask what i needed to do to get the best finish and what type of sand paper to use as i dont want to leave scratches but also want to give it a key for primer.
also wht the correct primer is to use
filler primer
http://www.halfords.com/webapp/wcs/stores/...tegoryId_165495
or
i have never tackled this kind of job before but i want a nice finish so any help would be massivly apprichiated.
cheers.
  • Views 2.2k
filler primer
or
cheers.
I would get some 3m scotchbrite pads and key the paint with that then a ipa wipe down if you are really anal use a tack cloth to get rid of any dust. Then just spray them the new colour as far as i know you wont need primer unless you are taking it back to bare plastic.
If you want to take off the lacquer over the paint use some wet dry paper but it will take ages i would finish up at around 1500 grit then do the same as above ipa wipe down spray a thin layer wait for it to dry then a few full coverage coats then 2000 grit paper when its dry to flat the paint back and remove any imperfections then dry it off and lacquer if its needed make sure you go easy with the laquer so you don't gets runs with it and make sure its fully dry before replacing or it will go funny like on mine:( i have one pretty much perfect and one with bad lacquer
If your planning on buying primer, then I would just paint the ones already on the car, as its alot easier.
So the ones untie car, cleanthem with something like white spirit, panel wipe etc, then mask up around them, so about an inch of tape all the way around, thenuse newspaper etc to cover the test. Use scotch brite on the plastic to key it, then use a few light coats of primer, then use 240 - 400 grit paper to flat it off, what your doing here is basicly filling the dips with primer, then flattening it all.then dust on a few coat of paint. Then lacquer it, I don't usually wetsand the paint before lacquering, as it never really works for me. Then once it's dried, so for say at least a Fay. Turgid there is orange peak that is really noticeable then flat it back with 1200 grit and polish. But this shoildnt really be neccessary if you take your time and use light coats.
As above, if your painting the already painted ones, then just a light key with a scotch pad will do, no need for primer, then a few light coats of paint and some lacquer. But then bear in mind you have to remove the old ones and refit these, which isn't an easy task in itself.
I'm of course assuming your talking about the door strips, the bumper ones are easy enough to remove, and will be better to paint seperately.
  • 1 year later...
When you sat 240 - 400 do you mean everything in between or just pick any? And is that wet sand or just normal grit paper?
