Electric windows
I'm looking to put electric windows into my 6n2 polo, has anyone done this, the universal kit way, or the moter+regulator way? i will be buying the universal loom and doing the wireing myself, just need some help on the mechanical side of the windows
  • Replies 10
First Welcome to CP
If you use the search function ( your best friend!!) you would of found this http://www.clubpolo.co.uk/forum/index.php?...p;#entry2501452 to see if the wiring is fitted, then you'll just need the relevant door looms and the regulators, there are two options with the setup, basic control or the "Comfort" with "one touch" control, they use different motors, the basic has a two pin connector and the comfort has 12 pins and the switches are also different.
The mechanisms are often found for sale on here or ebay, if you want new then GSF or ECP
They are for some reason more prone to failures than the keep fit mechanisms! snapping cables or breaking the plastic clips that hold the cables to the glass clamps but repair kits are cheap and plentiful on ebay
sorry, didnt know where to start! but thankyou! i was planning on doing a universal loom! just need a 2 wire motor just basics! could i use the 6n one in the 6n2?
Yes the basic two wire one fitted in the 6n or mk2 Ibiza(93~99) would be OK
okay sweet! would they fit fine inside the door panel? or would modifying be needed?
They fit to the same mounting holes as the keep fit mechanisms
oh okay thankyou! have you ever done this conversion?
I was going to do it on my 6n but that car ended up in the scrappy.
What are you going to do regarding the switches? as the standard 6n2 setup has switches in the door card for both driver & passenger on the drivers side and just passenger on it side, where as the 6n setup just has two switches below the heater control panel
I've done this using the OEM setup.
I've got the full gti heated leather interior installed! just haven't put the front door cards in yet as i am waiting to do the electric windows, i have got the switches + a few inches of wire from the bulk down to play with if i wanted to modify it into a loom myself!, and reckon you could give me a run thru on how you did it?
It's really not that hard tbf, it was the first job I did in mine, after people on this told me it couldn't be done! :lol:
Basically, drop the units in the door and having the wiring separate. I tried the plugs in the door first, but they didn't work. If I remember correctly though, the door had a ground, but needed a live feed. If you take the plug out the door so you can see, you'll see a section of the plug unused. I drilled through this to make space and ran a thick ish (2mm, ish) wire through it. This went to a feed on the fusebox. (Get on your back at lie under steering column, remove the cover and you'll see some 10mm bolts). I put a multimeter onto it to find the ignition live.
Whatever I did, I found the one that stays live 15 minutes after the ignition is turned off - which is PERFECT, I thought. It means the windows work even though the key is out, great when you forget to put them up!
Once your feed is run, get some Networking cable - Cat 6, whatever, and solder each wire on the loom from the switch onto the cat 6. I did this at the door section of loom rather than right at the switch.
Extend this loom from the drivers door to the passenger door, and match colour for colour on the loom there - this makes your passenger switch work from the drivers side.
The passenger side needs a live, too. Just tap off the drivers one/the one from the fusebox.
And that's it. I tied the central locking into the switch too, so it's proper OEM.
