Bonnet won't shut after fitting lifting stuts please help!
Please help panicking cos can't go anywhere it goes low enough just won't lock in place
  • Replies 15
  • Views 1.4k
they go on the rear bonnet bolts.
That's what I've done bonnet rear bolt to the second bolt on the engin bay part but the bonnets not shutting now it won't like clip/lock in place :s
Mabey it needs the catch adjusting? What actully happens when it's nearly shut? Can't be nothing major
It gets to the point of shouting and then the bonnet seems to move to the right n make a pop noice n it won't go in thanks pal
Silly question but you have got them the right way round?
Yeah am sure I have :/ I can't work out y
Post a pic of them up til we get a look. The gf has them on her Vento and they're a great job.
There is no right/wrong way is there? I've had mine both and it's always shut.
Chears guys I will take a pic soon as I'm at work ATM n ill post it later thanks for you are help guys
Where did you get them from? you sure they're not tailgate lifters and you be been sent the wrong ones? I'm sure that tailgate lifters are thicker therefore that might be your problem with not being able to shut your bonnet. Just a suggestion.
I got these ones....
http://www.ebay.co.uk/itm/Gas-Powered-Bonn...=item4844bcf0a1
they work great, had to drill a hole on the drivers side bonnet as the bolt on the passenger side did not line up.
All I can think of is there hitting the bonnet as you close it down?
If it moves to the right, the catch could not be lined up? Look at the catch while you close it, it should fall right in, if not it needs moving.
The catch needs moving?
Don't move the catch. If the bonnet shut fine before installing the lifters then its not the catch that's at fault.
The bonnet won't line up when shut either :lol:
I'm still going on what I said Because tbh when I had them on mine a couple of years ago as far as I remember it didn't matter out of the two which bonnet nut you used as long as you used the third nut on the wing (I think it was the third nut) it should be fine.
Did the bonnet/hinge move when you fitted the ball joints to them? If so then yes the bonnet has probably shifted out of line.
Alternatively the bonnet may be grinding on a lifter if it's out of line.
I don't know which ones you have and how they fit, mine were a fiver from a breakers yard - i just used a tape measure to discover Saxo tailgate struts were perfect. But if i had bought new ones from some random on ebay then i would expect them to come with full and wise instructions easily understood by the novice DIY-er, correct fittings well engineered for the job, and fit properly.
Incidentally, the Saxo ones fit to the front bolts on the bonnet, this puts less stress on the hinges. I'd be surprised then that a 'proper' set would be designed to bolt to the rear bolts, but if that's what it says in the instructions..
Sure they're not too long?
