POLO 6N2 BREAKING
Breaking 6N2 polo 1.4 16V SE 75BHP 2000 AHW ENGINE
TAILGATE WHITE £35
ABS PUMP £35
CENTRAL LOCKING VACUM PUMP £25
FRONT PANEL £15
FRONT BUMPER CRASH BEAM £15
RADIATOR £25
RADIATOR FAN £12
FRONT WIPER MOTOR £12
FULL SET 40MM LESOURS LOWEING SPRINGS 1 MONTH OLD £80
TANK FUEL PUMP/SENDER UNIT £25
DRIVERS ELEC WINDOW SWITCHES £35
PASS ELEC WINDOW SWITCH £5
JACK AND WHEEL WRENCH £10
SPACESAVER WHEEL £10
REAR SHOCKS £20
FRONT DISCS AND PADS 1 WEEK OLD £40
WASHER TANK AND PUMP £10
POWER STEERING PUMP £25
RADIATOR HEADER EXPANSION TANK £10
STD FRONT GRILL WHITE £15
BRAKE MASTER CYLINDER £15
PAIR TAILGATE GAS STRUTS £8
PAIR FRONT CALIPERS £30
BRANDNEW UNUSED AFTERMARKET TAILGATE SPOILER £35
COMPLETE 1.4 16V AHW 75HP ENGINE RUNS WELL £295.00
ENGINE PARTS:
CYLINDER HEAD LOW MILES £150
INLET MANIFOLD £10
EGR METAL PIPE £5
REVERSE LIGHT SWITCH £5
THERMOSTAT HOUSING £10
CLUTCH F/W ASSY LOW MILES £35
RED INJECTORS IN RAIL £35
STARTER MOTOR £30
COILPACK £15
THROTTLE BODY £35
EXHAUST MANIFOLD £15
AIR CON COMPRESSOR £55
KNOCK SENSOR £10
COOLANT TEMP SENSOR £5
MAF SENSOR £15
CRANK SENSOR £10
CAMSHAFT SENSOR £5
EGR CONTROL VACUM VALVE £15
AIR FILTER BOX £10
1.4 16V ENGINE COVER £12
ECU 036906014 £35
LAMBDA SENSOR £30
PM ANY QUESTIONS OR WANTING PHOTOS
  • Replies 15
  • Views 997
Il have central locking pump 25 delivered
Whats part nuimber ofllfor abs pump?
How much for drivers and passengers door handles with keys? Providing the locks work?
will look this evening
sorry they got broke when it rolled
Got the both the lamber sensor and the window switch mate ?
how much for the engine cover posted to egham?
cheers
If its a 5 door how much for window regulator and motor drivers side posted to Newcastle
All 4 calliper bolts (if not rounded) posted to Sheffield?
Thanks,
Does this have the 12v socket in the boot, and if so, is it available?
front bumper centre grille???
hey man could i get the steering wheel and how much posted
is the tailgate spoiler still for sale?
av you got the window washer hose going from the pump to the two sprayers? if so.. how much posted pal? nice 1
gear knob with gaiter posted?
thanks
