Strange noise on idle
My 1.3 is making a strange noise just on tick over and slight increase of reeves . but when its warm it does it all the time . its a bit worrying :(
heres the sound
Thanks in advance
  • Views 714
The winey noise? Could be one of your belts, like your alternator belt?
It could be:
1) As above.
2) Water pump.
3) Alternator.
Suggest that you use a 'listening stick' to pinpoint it - A length of dowel or a long screwdriver held against the above items, with your ear on the other end. Works wonders!
Regards.
heres the sound
Thanks in advance
Mine makes same noise possibly bearings in tha alternator
Its had a new pump an belt on it recently .
my old 1.0 also made the noise not as bad tho but i put the newer alternator on form the 1.3 so I'm betting on that tbh .or a belt being to tight
I will have a go with the stick trick towmorow thanks guys
