AVY BIG END BEARINGS
Hi ,
I've got preety much everything lined up for bottom end rebuild .
Only thing gsf dont stock is big end shells ..
I've seen them on ebay but thats in lithuainininnnina lol .
Know anywhere that stocks them preety cheap.
Also conrod bolts, Where stocks these cheaper than vw ?
I've heard of people reusing them.. also ARP bolts did they make them for the gti ?
  • Replies 65
  • Views 5.3k
Avy big end bearings are same as Afh mate
I'm sure mine were off eBay about £40 so may have been the Lithuanian ones I got can't remember
I have found some ACL racing ones I may get though
Oh and G60 and 20vt are same size too just remembered ;)
And for ARP bolts you need to search size bolt dimensions you need rather than car specific ones
More chance of you finding the ones you want but it's between £7 per bolt to maybe £45 for a set if your lucky
Edited by StinkyPete
Cheers pete :)
I got mine from GSF a couple of weeks ago for 29 quid.. do you want the part number?
That's good to know Mark
What engine did you get them for and can you post te part number or message me it too please
ahh it looks like GSF ordered mine in from FPS Car Parts.
I gave the the reg for a 1.6 16v AVY/ARC
The GSF code is SC705 which is Dummy Product and the other code is 01-4100 which is what I think is the external code for 4 Std Big End Bearings.
still bit nooby and may of confussed myself ..
Big end is a set of 5 rite ?
The ones what are bolt crank to block, Just making sure before i sound like a knob when asking to order them in haha
Big end bearings are the rods to the crank which there are 4 of
Main bearings are the crank to the block which there are 5 of
... I think! :-D
Sorry I've confussed my self . I need a price on main. the bigger set of 5 ..
Just assumed that big end was called that due to them beeing bigger lmao :/
I think the main bearings were 32 quid for all 5. Will add the part number from my bill in the morning. :-)
Ledgendddd :) Thanks mate :)
I got you a quote for mains and thrust washers mate. So they're what hold the crank in, you need big ends which go between conrods and crank, VW do the bolts, they're a bit specific for bearing cap location so IMO unless you're sure ARP ones will be correct just get OEM. But you'd probably pay more for ARP anyway.
Jamie I told you te gsf codes to get oem mains and thrusts you pleb lol
Why you getting so confused :/
Yeah if you can get those... Do :-)
Cus I'm beeing a bleb lol .
It was late at night lmao ..
Mark give me the correct part number first time round but i was beeing a bell lmao ..
Rite so got mains, thrust part numbers and price from pete ages ago .
Marks given me part number for big ends . I'll see what gsf can do or order in lol :)
Sowwiii guys
AFH HG, 16 stem seals, thrust washers & mains £51.70inc vat mate.
AFH Head Gasket or AVY/ARC one?
Edited by mark_crox
Yes NJH PERFORMANCE ..
I Know that ;) as per Chat ..
I just confussed myself when i wrote this..
Just searching to see if anywhere stocks rod bolts cheaper than vw :)
A few of my mates have reused them and said no problems .. But its like saying re using hg bolts is fine too :S lol
Re using HG bolts is fine :p
AFH mark as he's putting the 1.6 internals into his AFH block :)
:-D Make sense.. hard to keep up with what everyone is doing! :)
AFH mark as he's smashing the 1.6 internals into his AFH block :)
Naa yeah . Just feel its the easiest way. as i cant afford to re build and redrill others :)
Thing about rod bolts is you really really really don't want one to fail..
All 6n/2 petrol engines share the same big end and main bearings, ensure they have the holes in for the oil way in the rods though.
irrc its a oval shaped hole ?
Yeah but 5ver a pop for rod bolts from vw I'm kinda looking for other suppliers lol
