Mk 3 polo issues?
I'm going to look at a 1.0 mk3 polo tomorrow
(Some people might know them as mk2 facelifts)
Anyways I was just wondering if theres any specific problems with these cars?
Is there any place there known for rust issues?
Do they have pedal box issues or gear box issues like the lupo's?
So yeh just was wondering if there was any things I should be looking more for than I would on the average car?
Karl
  • Views 761
Rust on the wheel arches, rust around the filler neck on the sill and rust in the battery box (will leak making the driver foot well wet, take the battery out to check even if it is dry) then all of the normal second hand car things. Gearbox should be alright, it's 6ns that have poor gearboxes.
6n2's are the worst for pedal boxes and gearboxes, same problems as the lupo but the polo's are pretty much prone to all of these common problems.
As said above, rotten arches, under the battery tray they rot away, being a 10mm spanner and take it off and take a look. Only with the owners permission though, take a light too.
Fuel tanks get tiny holes at the bottom of the neck, barely visible but a pain in the arse to change.
Thanks for the heads up guys
As above, but with the fuel tank I wouldn't be put off the car completely if the filler necks gone. Mine leaked for ages, pretty sole destroying when your at the pump and it's leaking out straight away! I put the job off because people say it's a bitch of a job. New tank was only 40quid and I found it quite easy to change to be honest!
