Air leak stretched tyres
Hi all thout i was going nuts last nite park tha polo my street slopes 1 side so reversed into space and heard air comin from right front end jus a quik pttssttt, and heard it again tonite when i turn the wheel bak n fore to park, could it be not enuf bead seal?? Or psi in tyre?
Anyone else had this issue? I'm runnin 145/70/13 on front 7j weller
Any help be greatfull
  • Replies 29
  • Views 5.4k
what PSI are you sealing at and running?
Not sure bro tha garage put them on brushd a load of white shit on tha rim fitted them an off i went, will tha psi effect it? Do u know what psi i should be running with that tyre size?
If the brushed white stuff on it chances are that wasn't a sealer but a lube to help get the tyre on. I could be wrong of course but all the sealer we use are black
probably a stupid amount of lube left under the bead, then when your locking it it's breaking the seal.
take it back to where you got them fitted or to someone who has a clue what they're doing.
as for pressures, if you don't know what pressures your supposed to be running in tyres on your car then not even god can help you.
If they had "a clue what they are doing" they wouldn't have fitted a 145 to a 7 inch wide rim!
LIke!
Well i know a few thats runnin this tyre size with no issues, even on this forum infact, no need to harsh guys, was askin for advice rite size tyre the psi is simple enuf to work out, stretched tyres totaly diff ball game, i wanted a nice stretch i got it, personal preference init we all different!
Myself and a mate are running 165 on an 8j, and 45psi all round! I kept mine at 60 for a while to help the tyre take the shape of the rim. I would say keep it around 45-50 psi mate. All but one of mine keep air, one loses pressure at the rate of about 3 psi over 4 days odd.
You should never need to run 50-60PSI. If you run to high a pressure the impact your tyre should take is transferred else where. That and you will wear out the tyre un-evenly. You shouldn't need to run anything more than the standard tyre pressure recommended for you car. Even if you have a stupid stretch shouldn't need much more. I had 165/50/15 on a 8" wheel and that only needed 32-34PSI to be kept sealed. The recommended tyre pressure for the car was around 30PSI.
it can depend on the wheel mate, i have 165/40/16 on my 8.5j schmidts and it holds okay at 45psi, but my mates cossies at 165/40/16 on an 8j is constantly leaking and has to keep a air compressor in his boot. fronts will always go down more as they take more stress. But as i said, I've heard cases where split rims hold better, dunno how true that is though. just try running a high psi for now, if its still leaking at a dangerous rate then go to your fitters.
hope that helps :)
hope that helps :)
Cheers for the info guys funkyjord/danny braggins u been a great help with no grief jus advice:) I'm runnin 8j on the rear with 165/55 and ther great look tha bomb 2 but guna tak you are advice and put more psi in2mor to let the tyre adapt, it they lose a little psi evry few weeks then so be it, joys of the stretch:) thanx again amigos :-D
Hey dude, no problems! Nice to have a bit of help with no grief;) it does look the bomb! Hinders a bit if you wanna drive spiritedly but hey, always a straight road for that!
Just watch out on the corners!
60 psi? Lmao.
You do realise tyre pressures increase with heat?
And that tyres have a maximum inflation pressure?
Pissing in the wind Nick, watch your shoes :roll:
Don't put 45psi in your tyres please! That's just foolish, as mentiond pressure increases with heat,
As for letting the tyre adapt? That doesn't make sence, a stretched tyre is only the sidewall at a different angle.
I've never treated a stretched tyre any different, but then again I've never owned a 145 tyres! Take a picture low down from the rear of your car, it won't look so good anymore.
Yea exactly all of us need help n advice no 1nz perfect:)
Yea ill watch out for corners grown out of tha stage of takn bends at stupid speeds jus going for tha look homey:)
I ment take the shape of the wheel:) well 145 on a 7j looks pritty good with a 70prof went on easy enuf if i was a struggle i would of upt a tyre size dude jus going for the look, not as if I'm runnin big hrsepowa that my tyres are guna fold or the rim:)
To take the shape of the wheel? I'm pretty sure that tyres come in circles already don't they?
Can this thread just be locked ? Embarrassing to be on the website
^^^^LOL that made me chuckle.
It might just be worth going back to the tyre fitter and explaining what's going on and maybe get him to take them off and add some sealant, for the sake of a tenner or something it might save you a load of bother and might also allow you to run normal pressures?Just my 2p but I'm lazy like that. :lol:
Yeah if you run 80psi the sidewalls won't bend in as much.
Oh and don't go round a corner, may fall off
This is kinda embarrassing gotta agree with nick
The lack of common sense in this thread is unreal
