Polo 6n2 electric window switch wiring
Hi, I need help, I've bought two electric window switches for my drivers side panel but realised I've bought the passenger side ones with a different plug on them, it has the same amount of wires and obviously the switch is, and does the same actions, so I just need to know what colour wire goes to what pin? Any help appreciated.
  • Views 4.6k
The switches are internally different so it's not just a case of swopping wires around, the passenger switch has 1/4" tags and the drivers ones have fine pins?
Yes I intented to cut and put connectors on the wires for the new switch, only problem I have is the PIN numbers on the old switch are different to the new ones, and the old switches are non existing, so can't compare pins.
Anybody?
Anybody?
As I stated before the internal switching is totally different in the two types of switches, the ones with the fine pins are for use with the 12 pin comfort/closure/one touch motors, the 1/4" are for the basic setup
Thats not a problem I Dont mind having them without one touch, just need to know what cour wire is powe, earth, window up and down etc, so I can wire them to the new pins on the switches. Haven't got a wiring diagram either :(
Okay thanks for your help
