Adding AUX port to Radio?
Anyone know if you can add an aux port for the standard radios in 6n2s?
Like this one but with cd player build in too.
If not can anyone recommend a good fm transmitter for android?
  • Replies 10
  • Views 4.7k
Iv ordered a cassette to aux, ill let you know how it goes (Y)
I've used a cassette to aux and ended up buying a new stereo as it wasnt great. Kept asking me to re wind the tape and would barely ever work when i wanted it to.
The thing that Cymro posted is probably a lot better :)
"This item is NOT compatible with stereos that have the 6 CD Player built into the stereo"
Iv got the 6 cd changer underneath ]=
That unit underneath is not a 6disk changer. thats a single disk player, hence the disk changer is not light up.
It is on mine as iv replaced it with one.
Unfortunatly, you can't have both the changer and the aux in. Only other route is an fm transmiter
Check on connects2 website, they do a few units that connect to these radios.
Iv got a decent FM transmitter but over my 25 mile journey to work I have to keep changing station due to all the other frequencies, pretty annoying.
those cassette to 3.5mm jack adaptors do vary in quality, the cheap one will be crap, the ones made by the like of sony, belkin and phillips are likely to be better, they will also perfom better than most fm transmitters
I thought id try a cheap one, £2.50 ftw
