urgent requirement for abs pump
6n2 abs pump urgently needed
Will get part number but much be in perfect working order
  • Replies 9
  • Views 344
What's the fault?
I'm gonna bet you don't need a pump.
What's the fault?
Got warning light fault got checked and defective pump
Yeah, I've had that. Check the fuses on top of the battery. You'll find they'll be corroded. Replace them, or sand them down a little. Replace is easier tbf.
Clear the code and send me a tenner through Paypal. ;)
I'm also gonna guess that it's this code:
01276 - ABS Hydraulic Pump (V64): Signal Outside Specifications ...
Not sure what it said but ny mate whos doing my car said is not working
Get the code checked and replace all the fuses on top of the battery because I can't remember which one the ABS one is..
I bet it's that code though!
Can I replce them with any fuel or it got to be the same type? I mean like front inside car?
They're pretty big - like 30amp. Jump up to Halfords. I guess you could pinch them from another appliance you don't need JUST TO SEE IF IT WORKS.
I wouldn't go driving about with no headlights/brake lights, etc. Just go buy 4 fuses, they're like 50p.
Take them out first, I bet they have corrosion on them!
