6N2 Ventilation System problem
Hi all, during the past year the temperature in the ventilation system has steadily decreased until its barely usable now. In cold weather, turning the dial to maximum heat would give lukewarm at best. Similarly, turning the temperature ta maximum cold with the AC on barely cools the air. Another symptom was foam blowing through all the vents, which made me suspect that something was wrong in the insulation part of the system.
After searching a bit I found this: http://www.vwdieselparts.com/forum/viewtop...t=block+rebuild
What do you guys think? Has anyone had a similar problem?
How hard is it to access those flaps in the 6N2 dash? Thanks
  • Views 2.3k
Hi before you do the foamies route just check this out:-
Remove the little cubby hole (above heater controls) with a gentle pull
And check that your heater control cable 'outer' is located in its clip
Mine wasn't and bled system 3 times, used rad flush thinking matrix was blocked
And after all that I had centre console out to hard wire a satnav cable in and found the problem
I was nearly going to change matrix as no mater what I could only get Luke warm air!,
Hope this helps
Adam
Hi Adam, thankyou for your reply :)
I just checked the heater control cable and its still in place and definitely moving the flap. I also noticed that when selecting the footwell vents for example, it still leaks air from all the other vents (although not at full speed). I would like to do the job myself over a weekend and check things out myself, but I don't know which side of the dash to remove or from which direction I need to access it
Is your aircon the basic system or the climatronic? as there are big differences in the control sytem for the air flaps etc
Its the basic manual system, so it should be simpler to tackle once I gain access to it
Remove the glovebox to get better access and the trim under the dash, then this will help you check/adjust the cables/flaps
Thanks mate! I'm going to start with the cables and guide my way through them. I'll update this space if I get around fixing this myself
