6N2 Polo
I'm just about to buy a 6n2 polo and its a 1.4 8v and was thinking what can I do to that engine to get more power before I think of an engine swap
or should I just look into getting the 1.4 16v 100hp engine and do that up ??
  • Replies 8
  • Views 991
16v or conversion are better ideas IMO
If your going to go through all the hassle of a conversion may as well put a GTI in it. Extra 25HP for doing all the same work.
I agree, gti would be the way to go
Or buy a 6n2 tdi much easier and cheaper to increase power and torque.
Didn't think of that, would the actual conversion just be as easy?
you'll have to change the tank and all the fuel lines... just a bit of a chew on really.
Not worth converting 6n2 to gti or tdi, hassle when insuring, selling etc. Just look for a stock tdi in se spec.
Its not really a hassle though. All you do is say "it has a 1.6 16V engine instead of a 1.4 16V". They will most likely ask you for the new power output and thats about it.
