1.48v to 1.4 16v 6n
I've chercked the FAQ and there are so many different stories about the conversion.
Am i right in thinking i need the engine the ecu and key and the loom for the conversion but i can still use the 8v gearbox its a p reg 8v and i have been told that a 16v will plug straight in to this loom??? How true is this?
Cheers Chris
  • Views 798
you can use any gearbox you want from the 6n apart from the diesel box provided the linkage type is the same.
i'm using a 1.4 8v box (DQW) on mine due to the longer ratios over the 16v box.
the looms on the other hand i have little experience with as i swapped the entire electrical system to the 16v, other than saying all the connectors look exactly the same where the engine bay loom plugs into relay board under the dash, i cannot tell you if the pinouts on the connectors will match.
