1971 Squareback - £2600
Make: Volkswagen
Model: Squareback
Year/Reg: 1971
Mileage: Showing 49k but no way of knowing
MOT: August 30th 2013
Tax: Exempt but till March 14
Price: £2600
Good points:
Really pains me to be selling this as I love it and have done everything I needed to make it reliable and driveable. Would love to do another show season in it but I am relocating and so have no real provision for a second car in York.
1600 TP engine on stock twin carbs that has had a full top end rebuild over the winter. Stripped it back to the pistons and barrells which were in good condition. Sourced some 2nd hand heads that were checked and in perfect condition. Rebuilt up from there with all new gaskets.
It then went to Harry Harpics in Leigh-on-Sea where Paul serviced the whole engine, set up all the timing and choke etc.
Got a brand new Fuel Pump at this point as well.
Lowered but not slammed. Not very bumpy but the rear spring plates bottom out on big hits which is loud but not really an issue.
Completely solid. Some of the welding is not to a show-winning standard but it is perfect all over. Inner arches, spring plate mounts you name it, its solid.
Tyres are all very recent and seen less than 200 miles
Early low back seats
Brand new battery I have done about 3 miles on!
All on 1 key
All in all, it is a very solid and reliable Square. I really like it as it is clean enough to look nice and presentable but ratty enough to be able to just throw the seats down and sleep in the back. Just means you dont have to treat everything like a show winner.
Bad points:
As mentioned, the welding is not show winning and so there are a couple of different paint colours on the interior. (some red oxide where stuff has been done and the original green)
Paint was homedone by a previous owner so it is far from perfect. Some orange peel and a couple of bits look brush painted but it is all fresh.
The diff bearings are quite loud. you can hear them in the lower gears but you get used to it. I chatted to Paul @ Haryy Harpics about it and he wasnt concerned at all. Said they are pretty bulletproof so confident they will keep going for ever. If you rev the tits out of it in reverse it occasionally pops out. Would only really notice if reversing too fast.
No Speedo cable attached. One brand new one included in sale
Pass window is a bit scratched
Pass indicator is cracked and I have patched it together with duct tape. Not very pretty but does the job and I will be looking for a replacement as I go so it might be sorted by the time it is sold.
Chelmsford, Essex
Pictures:
I have more pictures of the usual areas and can email these but dont want to mess up the thread.
Contact details:
zero 7701 085 23three
Or PM on here
Square is kept under cover/in a barn so next time it is not cold and wet I will get some pictures of the usual rust spots to show how solid it is.
  • Views 658
this still for sale, have cash?
