mk2f/3 window wipers
Hi all,
Does anyone know whar size the wipers are front and back ?
It's a 1993 coupe ( also, is this a mk2f or nk3?)
I know I can just measure them, but the car is 200 miles away and I want to bring new ones with me
Thanks guys
  • Replies 11
  • Views 2.3k
18inch of front bro i beleive its tha same on rear, would measure mine but I've de-wiperd it sorry, dont worry bout rear so much ope this helps :) wel sum peeps call em mk2fz sum call em mk3 load a pic dude ill tell u strait away or call me 07528059803
Edited by Vdubdud3
Showing same for front & rear
161955427 wiper blade with wear indicator 400MM VALEO /
Thanks guys,
So 400mm is roughly 16", but would 18" fit on the front? Or are the smaller ones better?
Thanks again
Thanks guys,
Thanks again
400mm is from etka/vagcom
Thanks bust, il stick to the oriinal size then...Vw can't be wrong.
You need 16 inch blades, I tried an 18-inch one on mine and it goes over the windscreen rubber.
16in max on the front passenger's side, and 20in max on front driver's side, of MK2/MK2F
18in max on rear of MK2 coupe. I'm not sure about the rear wiper of the MK2 breadvan or either of the facelift models.
I should add that some driver's side arms are too weak to hold a 20in at high speed, mine skates it's 18in over 80mph, but i figure 80mph is more than enough in the rain anyway..
Thanks guys
I'd by lucky to see 80 in the dry, let alone in the rain :)
18in wipers on a Mk2F clip the underside of the rear spoiler. Lightly, but it's annoying.
I don't see the point in putting massive wiper blades on the front. I've never struggled to see out of the screen because the blades are too short. I'd also much rather have a 16in blade wipe the screen properly on the motorway than "upgrade" to something which lifts at high speed.
Sorry, don't understand the logic there.
True, I got 16" all round, I seriously doubt Vw would use them if they weren't right. I just thought I'd ask incase the newer blades worked better if they are a little bigger.
But... I guess it's true, bigger isn't always better :lol:
one way to get around them lifting, buy aero wipers :)
