Electric windows and central locking have a mind of thier own!
Hi guys,
I have a 9n and it has decided that it is going to sit on the drive and unlock/lock itself periodically whilst opening the front windows! It doesn't have remote central locking so I'm not going mad! I have had a look at it this afternoon and removed the electric window fuses, this seems to have worked for now, the car is still locked as we speak, however when they are put back in the windows open almost instantly. Has anyone else heard of or experienced such an issue? It is really quite strange, I've had ideas it might be microswitch/sensor related, it has to be linked to the locking though as I know the windows can open if you hold the key in the lock while unlocking, but the car is unlocking and opening windows without the key in sight, not ideal to leave anywhere!
Hope someone might have had this issue before and be able to shed some light, I wrench on things for a living, it just happens they fly not drive and I never have any involvement in electrics of any sort, so mechanical problems are generally easily solved, this just has me perplexed!
  • Views 846
I'd start by checking the wiring between the door frame and the door inside the flexy rubber tubing, there might be some broken/chaffed wires that are touching hence the problem
Good idea, Ill go and have a look sometime tonight
