Removal of plastic casing to get access to sidelights
This is going to sound really stupid but I need to change both my boring yellow side lights to a set of white LED bulbs but having trouble removing the plastic casing so i can get access to the bulbs , it wont move at all ! its so stiff .. whats the easiest way to get it off people ? ....
  • Views 1k
There's a metal clip over the plastic bits pop it off to one side (only go one way) then pop off the cover
is it on the top or on the side of the plastic cover dude .....
Gti headlights have to come off to change the sideloghts. There are three screws holding the back cover in, you may be able to remove them without taking the lights out, but it isn't easy.
cheers guys will attempt to change the bulbs over the weekend
Remove bumper is much easier mate trust me I can't get a screw driver to the backing of the cover
you can do it without taking the headlights out or bumper but you might need to move the battery and use a stubby screwdriver that how I changed mine
