Naz’s 6N Polo Build
2 things
Fuel pump was knackered and not delivering anywhere near enough pressure which explained why it was wanting to start but failing so put a new S3 one in which got the car started
Wiring was a bit out as well.. the car started but had a dead pedal... once that was sorted the car wouldnt switch off :lol:
but after a bit of messing around its all sorted
So the todo list
Fix oil leaks
Add catch tank
Re-fit interior
Fit Gauges
Re-cut the slam panel as the current one looks like a bit of a mess
Buy a brake pedal switch and fit a new clip on the back of the brake pedal (pedal makes a weird clicking noise)
Add and bleed the coolant system
Pin in the EGT sensor
Get the car tracked
Run the engine in with mineral oil
Change for normal oil and send it for a remap
Edited by no1naz
  • Replies 90
  • Views 24.4k
getting there dude =D
i'm like a proud father right now...seeing that car moving...BREATHTAKING! lol
Glad the wiring was sorted in the end, bit of a frankenstein wiring setup :D
Always had doubts about the fuel pump...so another thing sorted there nicely!
Crank side oil leak will be a bitch to sort unless its just a loose bolt that was overlooked, lets hope its sorted soon...i know you're itching to take this car out now. :unibrow:
Looks like u and Sanj have put a lot of work into this . Hope to see it a show soon . Good luck with it . Dave
Thanks mate... the effort gone in was crazy... i think we both underestimated how much work was required to make it work
I dont think it was helped by the fact that i kept pushing more onto Sanj like the big turbo and big brakes
but hopefully its not too long before its fully ready for the road :-D
This is Epic. A lot of inspiration for mine. Any update on this?
Keep going man, This is such an achievement!!
How strange.. i was just about to comment on you are thread on uk-polos
i saw u had a problem with you are driveshafts... i measured one of my shafts and took a pic of its length.. when i find the pic il let u know
no updates for now
just waiting on the guy who did the rebuild to get some time to sort the crank oil leak and then i can solve the other leak and get this engine run in properly
I did start putting the interior back together tho
Haha that is a coincidence. Thanks for the help man. Will need all I can get
Naz...saw the thread on Tee's mk5...nice to see we may have given some inspiration on the subframe box mounting ;) and i also noticed the crackle black powdercoat lol...nice build thread either way
...cant wait to see this thing sorted! :-D
yeah including that build that makes maybe 5 1.8T builds almost done
I've hopefully got someone coming to fix the oil leaks in a week or so
and then i can make some more progress on this 8-)
Thats good news with the oil leaks! Can't wait too see what power this beat will make.
I just hope I can get mine mapped sensibly, not shooting for figures just driveability.
As soon as i have the leaks fixed I'm going to book it in with R-tech, i hear the wait time is fairly long
But that will give me the opportunity to run in the engine and sort any more issues i find
I think I'm gonna go for maximum power on this
I'm hoping the stiff mounts combined with the stage 4 clutch and LSD should help with driveability
In theory it should work well
In reality tho... I'm not sure :lol:
Yeah R-Tech are the place to go! Thats where I'm going to be taking mine, not sure on the waiting time though but i do know they will have it for a week or more.
HAHA! Its should help in theory ;)
So had the crank oil seal changed, cambelt was an absolute mess
you can see the thin layer of oil all round the cambelt so fitted a new one
luckily we changed it without taking the engine out
also we identified the other oil leak and should be an easy fix
but we found a few other little problems, but nothing too major
so time to make some more progress
I'm currently buying in some parts so i can make one last push to get this car on the road
Catch tank was next on my list
I bought a generic ebay catch tank... pure rubbish
I then bought a Jaz products one which was a bit better but the outlets were not suitable for a 1.8T
I looked into the Saikou Michi catch tanks which ticks all the boxes but at £100 is a bit expensive
So i used that in mind to make my own
So I bought another generic catch tank and modified it
Picked it up from the powdercoaters today
I've been looking at catch tanks and like you say the only ones that are really suitable are exspensive. Think I'm going to make my own as I've literally just seen some nice aluminium tubing on our scrap rack at work ;)
The only thing good about the expensive ones is they have an inbuilt filter within the tank itself, but I'm venting to the atmosphere and am using two filters to do so
If you are running it back into the intake the expensive one is worth the money i think, the damage the breather system over time is worrying
But if you are doing what I'm doing then definitely make it urself... i made both of mine, added the correct inlet/outlets and powdercated them for under £100
Yeah think thats the best way to go, I'm going to vent to atmosphere too. All i need is some weld on ali fittings and mines done!
Haven’t updated this in a while, but have been pretty busy on this
So started by identifying the last remaining oil leak, Turned out to be one of the outlets for the oil temp/pressure sensors
We tried some PTFE tape to create a seal, this only reduced the amount leaking
I was about to buy a whole new unit when i was recommended some Loctite which creates a seal around the thread. This seems to have stopped the leak completely
So will keep an eye on it just to make sure the leak doesn’t re-appear
I then started looking into the clamps that were given to me by simply supreme when my intercooler work was done. They gave me some Mikalor ones which have very mixed reviews on the internet.
After some research I paid SFSPerformance in Luton a visit and bought some Murray clamps. They gave me a very good price on them so picked up a bag of them. I would recommend them to anyone who is looking for quality clamps or silicone hosing
Here is a comparison against the Mikalor ones. The Murray ones look alot better in my opinion and apparently are much better functionally
Next was to sort the broken Powerflex anti-roll bar bush. All Powerflex products have lifetime warranties on them. A simple call and some new ones were sent over
The old bush looked like it may hold but I didn’t want to take any chances
Once removed you could see some considerable damage to it, I’m happy I had it replaced
As far as I could tell car was ready for a start
I was planning on getting the car properly up to temperature so filled it up with water to test it.
As I the water filled, I noticed some water was dripping onto the floor.
The leak was coming from the turbo water line. I removed it to find this
Went and visited a local hydraulics company, Hopespare who made me a new line for £30
So started the car this weekend and finally had a car with no leaks
Car idled and came up to temperature fine
So my to do list, in order
Send car to bodyshop and have aerocatch's fitted to bonnet and front bumper modified to accomodate the intercooler
Fit brake pedal clip and switch and test it
Fit catch tank
Re-fit interior (half done)
Buy wider Porsche adapters
Get the car tracked
Test fans
Fit Gauges
Send it for a remap
Good progress 8-)
Nice one man! Almost there ;)
So went to test the fans on the car which meant running the car for a long period of time
Checked over the fluids in the car when i noticed the power steering was low so topped it up
When the car was started we noticed the power steering pump was leaking
Removed the pump to find this
The original polo pulley was not shallow enough to use so we replaced it with a 1.8 T golf pulley, but it seems to be too shallow
So replaced the pump and spaced the pulley out by a few mm's
Seems to run fine now
Then moved back onto the fans and more bad news, fans did not kick in at the right temp
Measuring blocks on vagcom had the temp of the engine at 106 degrees but the dash had the temp at 90
Both should be getting the engine temperature from the same sensor so not sure why there is a difference
Car is going to the bodyshop now to have front bumper and aerocatches fitted
Have spoken to James at OBD works who will look into the problem with the fans, pin in the EGT and wire in my gauges
Will book it in when the car is back from the bodyshop
Hoping to have the car ready for the road this month
Here is how its currently sat.. slowly coming together
Edited by no1naz
Stunning project.
great thread fair play to you :)
