cup holder and coin holder
how do I removed the cup holder and coin holder from the holder that holds them both together?
  • Views 937
On mine (Lupo, should be same as 6n2) there was a bit of sticky stuff at the back sticking both drawer units to the main housing, rip this off it's not needed. Then there's 4 clips - 2 for each drawer - at the front end. Start at the corner & get a screwdriver in to prise the clip down and pull the drawer unit out a bit. Stick a small screwdriver or something in the gap to stop it clipping back in while you get the other one out. Then unclip t'other side & pull the drawer unit out. Repeat on the other side if you need them both out. Bosh.
ok thanks
