6n2 1.4 16v Rocker Gasket?
So my car started missing the other day so i was looking around at things that could be causing it, i was checking the plugs when i noticed oil in there i looked around the internet and i saw that it could be the rocker gasket seal so i looked on ebay and there is 3 different types for the 6n2 1.4 16v. I dont want to rip the old one off and damage it even more without having a new one to replace it with, if anyone know what gasket i need can you please link me it would be greatly appreciated.
Thanks!
  • Views 852
Thanks!
HI,to be fair a genuine vw one wouldnt cost the earth so maybe get in touch with your local main dealer and give them your reg and they should be able to do the rest for you and if your ok on the spanners you can fit it yourself?Hope this helps :-D
Thanks!
Yeah sounds like the best bet, will get one over the weekend thanks :)
Thanks!
No worries hope they can sort it for you and you might want to get a small tube of gasket sealer too just to be on the safe side.
It hasn't got a rocker cover gasket. Technically it hasn't got a rocker cover - well it has, but it's also a cam carrier as it houses the camshafts. For this reason you'll have to remove the main cambelt in order to remove the carrier plate.
As you can imagine then, there are oilways going into it, and it's an ultra precise fit. The 'gasket' is just silicone sealant, which needs to be applied as an ultra thin film, as any excess can destroy the engine. In fact, just don't apply any around the oilways.
Remember though, to apply it around the spark plug holes as well as around the outside - it may be it's leaking there because someone forgot, after all the carrier is bolted down very well.
It is leaking into the spark plug, think i would be able to seal it up by taking out the plugs and doing it that way?
There's no harm in trying. The stuff VW sell is similar to kitchen/bathroom frame sealant, which iI use as its a fraction of the cost. It can adhere, if weakly, to aluminium.
There's no pressure behind the oil though, so you may be onto something. Well there shouldn't be - check your breather system is working well. Some of these had additional breathers in the carrier next to the cam position sensor, such as this '04 one in the pic..
Okay thanks a lot your help is appricated. Il give it a go il keep posted on what happens.
