6n2 foglights
Hi all, I want to fit gti fog lights to my 6n2 sdi,
I was wondering if the wiring is there behind the bumper?
If so do I just need fogs and a new switch?
Many thanks Adam
  • Views 808
Yeah I just fitted a set to my TDI, literally the plugs for the lamps are clipped up behind the fog lamp grilles (capped off to stop water entry) just fit a switch with front fogs and away you go, you can't have the speedo/clocks tell you they're in like the rear fog unless you get new clocks
Plug and play though no fuses or anything needs its all there.
New switch + fog lamps + grills is all required
Plug and play as matt said
I also have everything you need to fit the fogs for sale
