Megajolt trigger wheel
Emailed trigger-wheels.com (megajolt) about:
http://trigger-wheels.com/store/contents/en-uk/d45.html (16v engine)
They wanna know what crank pulley I've got and measurement of it's diameter so advise further on the trigger 36-1.
I've been on ebay could not find a thing. Searched on google and could not find one except for a standard 6N 1.4.
Is only place to get the dimension from VW dealers? Would they give that kind of information out.
Wasn't sure weather to put this in ECU or engine dep forum. Any advice from Mergajolt users is appreciated.
Edited by damunk
  • Replies 16
  • Views 4.9k
Iv just made a trigger wheel setup for my car mate.
Few things to consider, such as clearance to the chassis leg.
The 16v crank pulley is wider than an 8v - does it only have a single bolt fixing for the AUX pulley or is this a AVY thing?
The 4 tapped holes are not equally spaced, I have a trigger wheel with slots so you can accurately adjust the wheel to the sensor for your TDC reference. Cost about £20 inc plating.
Assume you want 36-1 on what car? What shell?
Nick
Nick
36-1 on polo 16v 6n AFH. Want my mechanic to set it up before I put carbs on and take to bogg bros, but want to supply him with all the correct trigger wheel, brakets so he does not have to mess around.
Was looking at a kit for around £320 from trigger-wheels.
I'm having KW's Weitec coilovers (now gone up in price alot) going on this car on Friday and if you notice I made a thread about a oil patch on the plastic timing belt cover.
The guy is taking all day to put the coils on so I hope he can quickly take of the cover so we can see if everything is alright.
At the same time I can see the crank pulley.
I think it is just one middle bolt type pulley.
Edited by damunk
Buy the bare minimal from Trigger-Wheels, just get the ECU and connector really, other stuff they sell is cheap shit IMO.
Get a sensor to suit what you want, get an EDIS Module from a scrappy with the connector, TPS to suit the carbs as you wont have to mess around making a universal one fit.
Crank sensor, a mk5 fiesta zetec S has a fairly compact one with an angled part for the connector, its a bit tight for room on my car so this mattered also.
Cant even remember what a 6n looks like down there now :(
Is that the TPS sensor already on the carb?
Yes mate! Slightly newer carbs than mine they are, but will work the same none the less, they're a linear variable resistor I beleive, mine certainly is, connected to a 5v supply you virtually get 0.1v-4.9v reading, thats through the whole range of the sensor, so obviously on the carbs it is slightly less to allow for sensor position/not bottoming it out and snapping it. Now my ECU isnt broken it works fine, as it does on my friends car(s) which have been on megajolt and megasquirt :thumbsup:
Ill just look for some pics for you.
Thanks man, so I don't need a TPS? If so that's some of the cost trimmed already :)
Is that the sensor you have above. It's from a FORD FIESTA 2001 MK5 1.25 ZETEC.
Anything will work mate, thats a cam sensor i think, my plugs at 45 degress, that would work though, looks compact. sensor gap needs to be around 0.8-1mm from the trigger wheel.
Mocked this up on an old 6n engine in the garage..
Changed to the earlier pulley for clearance..
Ribbed Type
83e79346f1d73168ebf83a76985cd588_zps2c3b
V belt type
89f87b7da067a6a95802f6563cd487e8_zps8fd8
Note, had to mod cambelt cover to clear this.
Machined myself a hubcentric spacer to bolt through to mount the trigger wheel...
7fc572a2df37f9052eeab174a161a6b7_zps8236
71e2e961046574f0d31ccea8602f4144_zps2df0
And made myself a bracket to mount the Ford coil pack & a distributor blank (retains a standard dizzy O ring)
e6749a43efd6c988f3f76de282eefb40_zpsfac5
73caf3546af9a1cb794515392bac7c7e_zps3152
Spacer to clear the dish of the pulley
a4c7b0da8210626ec5b4a0c52098f52b_zps21bd
Wheel bolted into place..
f9b83e166053bf2b4d3c433473912b21_zpsa0d6
Started mocking up a bracket..
19fb4036a7b964ab34c09bfda769693f_zpsef77
27ea1e5e1d82a8e5d73fe4a72ccaedc7_zps889a
Welded it together and checked for fitment..
fd598df1bb122714985be0ada5aaf75c_zps493c
On the car..
6a827fde5acd3f2078cdc8943093215d_zpsa0ff
d3837b141be7c9a74ebd253bda8b3475_zpsc9e3
82dd7176d49cac3c4f6c6b2e01603646_zpsd015
Install...
32049f3def68bec696a84707885aa6a5_zps310f
04b5bb3ba487dd3377116d72ae9ea37e_zps2bde
Oh and heres my TPS (Said mine was different)
e117a7a03b479d8788bc61313e70ac34_zps2133
Id do a few things differently perhaps if I did it again, but it works fine.
Need to make one for a 16v soonish anyway but probably not before you do lol.
Hope this helps..
Well the way I'm going I'm not sure if I will do it before you.
Man, that trigger wheel looks right close to the limit.
Is that in a 6n 16v engine bay?
Also could I get away with standard ribbed pully and just make the spacer half inch shorter?
Nah thats a mk3 bay lol.
Yep Yep. lol sorry.
Right, anyway that spacer looks good quality. If my pulley is same one. Would your spacer fit? (doubt it as it's a diff engine lol) Because I need to do something. Would you make & sell? Can't imagine bogg bros or my mechanic wanting to naff about like this.
Edited by damunk
Not sure yet dude, I need to see whats tranferrable to the 16v, measure some offsets etc! Anything I machine is staying behind in my own time at work, cant just bang it on a CNC machine whilst I'm doing other stuff unlike some people have the luxuary of :(
http://www.ebay.co.uk/itm/VW-mini-adjustab...=item1c31633486
this trigger wheel do the job?
Don't know why trigger wheel want my pulley size.
They only sell universal trigger wheels and ones for a ford or rover.
Edited by damunk
Yeah thats what Iv got mate.
The PCD of the big block VAG engines (KR, ABF etc) are the same for the aux pulley.
You could space it easier, or mount it behind and then respace alternator pulley perhaps
Did you go the megajolt route to get better carb setup? Instead of using mk2 coilpack , loom etc
Megajolt would give you better map-able timing to get the best out of the carbs?
BTW the above trigger wheel is mini light weight 121mm according to ebay description. That's small. Is this correct. :)
Edited by damunk
Just checked the crank pulley is def the ribbed type and man theres hardly any clearance.
It is just one BOLT straight through middle.
2 thirds of the pulley is below the metal structure so thats clear. top 1/3 is not and is as close to the metal as picture suggests.. I wonder if a mini trigger wheel would fit.
Where does the alternator belt go to? Is thank running of the crank also?
Is there only one timing belt in afh? because the pully seemed to be hanging out from where the cam plastic cover is.
Edited by damunk
