petrol cap lock
does anyone know where about the tube from the central locking to the pin that locks the petrol cap on a 6n2
  • Views 867
Popular Days
The pipe connects to an actuator, which then pushes a pin into the cap. If you pull the foam piece that holds the pump away from the body, you should see two screws intoa panel, if you remove them the whole actuator comes out, or you can reach behind and pull the pin down.
