Another petrol flap question
Should there be an insert in the cap that the locking pin slides into?
Mines just an empty square channel and the locking pin is a poor sloppy fit. It seems like there is a bit missing that fits into the flap so the locking pin has a snug fit. Am I missing a bit or is this normal?
  • Views 964
sounds normal mate, mine will still open about 10mm when locked as the pin is smaller than the hole
Cheers. Sounds like a mod is required here :grin:
Let me know what you do, may attempt the same!
