painting bump strips and lower bumpers on 9n polo fading out
Hi guys I've got a reflex silver 9n and I'm going to have a bash at painting the bump strips and lower bumper parts to match the existing, colour coding if your getting technical.
But what I would like to know is, has anyone, used the fade out spray in a spray can because I would like the lower bumper parts to be not as noticeable, I will be spraying everything with rattle cand, any advice will do.
  • Views 1.2k
I've not heard of fade out spray but i have colour coded my bumper strips and the rear valance/bottom half of the bumper. I may be wrong but i think part of the problem with getting the colour to match might be to do with the texture of the lower part of the bumper and also the bumper strips (as well as the paint not being a perfect match). I recently re colour coded the rear bumper strip after using high build primer and then sanding the texture off so it was smooth like the rest of the bodywork, that made a big difference to how it looked imo
Thanks for that, I've brought some high build primer too so will try that. Did you spray the bumper On the car? In a garage or out side?
For the rear bumper and bumper strip i took it off the car and did it in my garage, but for the front and side strips i did them outside during summer last year. The rear bumper takes no time at all to take off so id recommend doing that. have a look on my build thread as i wrote a bit of an explanation on that. It takes a fair amount of time to get the bumper strips smooth with the high build but is worth it in the end as i much prefer them smooth to textured
build thread : http://www.clubpolo.co.uk/forum/index.php?showtopic=296597
