premature speaker failure
iv had 3 speakers fail in 2 weeks, is there any possible reason this is happening?
  • Replies 78
  • Views 13k
What speakers? What amp, how meny?
both of the original speakers at the back failed from my mk2 bready, they were old and tired looking and somewhat deteriorated.
so i then bought these Pyle
heard good things about them from people on here, installed them less than a week ago and one failed today, no amp, running straight from a normal headunit
I see, what headunit are you using, and what settings on the eq like bass/mid/treble ?
I'm not surprised they died tbh no way that will handle 120w rms
Headunit
not really a powerfull stereo from my understanding
where have i gone wrong here then?
bass -2 treble +2 mid 0
Edited by stormintrooper
thats beleaved to be 20w rms to each speaker that wouldnt of over powered it, settings would be ok i would of gone -6 on the bass
think its just the speakers better brand is needed alot more reliable and alot better sound
my old headunit running my doors on -10db on the bass still kicked out too much, so maybe yours is doing that and if your volume is over a certain level it destorts and that may of damaged the speaker
every headunit destorts mine was 60 on my alpine from 0-62
but just change the speakers for a better brand sorted and them amp them
my theory is that you are turning the volume up too high and sending a clipped signal to the speaker. clipped signals will kill speakers very quickly
i may be guilty of playing metallica full whack all the time mwahahaha
so to keep the volume I'm seeking i definetely need an amp?
to avoid this clipping?
Daft as it sounds, new speakers should be "run in" they shouldn't be used anywhere near full volume until they've been used for a few hours at lower volumes ;)
Can still clip the amp even more so if it's not scoped gain set correctly, but the headunit you shouldn't turn it up past the clip point depending on the headunit I'd say 90%
New speakers run in, it's only subs that need to be doing that to free them foam and spiders to stop damage from excursion and mid/speakers shouldn't be running much bass anyway
so in plain english? lol
what do i need to do?
You need to spend more than £20 on a set of speakers from a brand no-ones heard of.
I'm sorry to be blunt, but you only get what you pay for.
Playing hard music (with hard bass notes) will kill speakers very quickly, cheap ones epesh.
If you want loud, you've gotta pay. You want to avoid running bass through small speakers - leave that for a sub..
i suspected as much, however iv noticed 4x6's arent easy to come by,
can anybody recommend some more suited to my needs?
run the front and rear off an amp with the alpines there cheap but will be alot more reliable, but you still need to remove the bass from them but the amp can do that will sound alot better without any worry of any damage
if the amps set correctly mind
as admitted I'm completely clueless with car audio but those alpines have a lower rms than the pyle?
wouldnt i be over powering them with an amp?
some are genuine rms but some are dreaming like the pyle, theloudest.com speakers and many other brands, they will take more if its cleap signal the alpines that is
I've got 100w RMS Diamonds in the front of mine, and they're so loud I can barely have it full chat for any length of time.
You get what you pay for. :)
how much did they set you back? i need some decent volume as I'm loosing my hearing so volume is key :-p
just those pesky 4x6's
is there a decent one anyone can reccommend that will take the punishment?
All depends on budget if i was you buy a set of components vibe,jbl,alpine,inphase,ground zero,herts, many more then run them off a small 2ch amp so no rear speakers as there behind your ears anyway, then a small sub for the low frequency as I said before your welcome to pop over and have a chat on what and how to make it sound good
I never have rear speakers in any of my cars just decent components up front so speaker and seperate tweeter
so right next to your ears therefor louder
Then a sub, so only mid and high frequencies on the front speaker to minimise chance of damage
2-way components from £30+ second hand or £50+ new
Edited by madmike87
sounds good, I'm still determined to have front and rear though :-p
only issues i have with a sub is id want something small and discreet
That just means more money and not much differance
Yeah if you don't run a spare wheel I can make a false floor or even a box that would fit at the side in the boot
I've still got 4 amps and one sub left
Edited by madmike87
its better but try and spend that extra for the front
remember you need an amp for the sub
or use the fli 4 channel running the front and the sub, then dont run rear speakers saving you money to spend on better front speakers
so that would be 100w rms for thr front and 225w rms for the sub
I'm selling a better spec sub for the same price its a 12" but will be more reliable
and a better amp for £50
Edited by madmike87
