Anyone used the Torque App on their Polo?
There is an app on android marketplace called "Torque Pro" that gives you everything you need to know via your car's OBD2 port.. performance, 0-60, guestimated BHP, Torque, faults, diagnostics etc..
Loads of great reviews, works well on my mates 306 but I'm not sure we can use them having the stupidly strict VAG Protocol OBD2..
Anyone had any luck? be interesting if so, I'll invest..
Context: https://play.google.com/store/apps/details?...orque&hl=en
  • Views 2.6k
Invest and let us all know ;)
It should work on petrol 6n2 onwards and for oil burners late 9n1 onwards
I've tried it with mine, nothing. Can't seem to connect to the ECU, just gets confused and fails.. I think VWs may be the only cars that can't :/
Something to do with Vagcom, they seem to have exclusive access or something.
Looking at your profile info your 6n2 gti should be EOBD2 and give the "P" codes alongside the VAG five digit codes. In the manual for your engine it certainly lists the P codes with the corresponding VAG codes. Connect your car up to vagcom/vcds click on the "OBD II functions" tab to see if it is compatable. I know my Ibiza of the same era gives out both sets of codes
