Picture request - mk2 door
Bit of a favour, I need a few pictures of the hinge/check strap area on a mk2 door. I need one taken from inside of the area with the door closed, partially open and wide open please. My doors are currently off getting painted
  • Views 877
i dont mind taking a pic for you..but dont really understand wht you want? pic with the door closed?
Yeah, I need 3;
Door closed (from inside)
Door half open
Door wide open
All close ups of the upper hinge/check strap area
Basically I'm running some rubber grommet/channel things for door speaker wiring (like on modern cars) and I want to see the best place to fit then. I don't want it getting trapped or fouling the hinge/check strap. Should have done it before I had the doors off but I forgot :?
