Never had a Coupe before, but now I do.
Hey guys and gals
Just got this little "hatchback" off of a mate and I'm gonna try and get it
Up and running in time for deutschland @ modified nationals in may.
Wish me luck.
Edited by ten_ton_tone
  • Replies 26
  • Views 2.3k
Banded steels are coming along nicely
9.5J on the rear
7J on the fronts
That's a Breadvan and your gonna have your work cut out with the rear arches lol!
lol, those wheels will never fit without some insane arch work up back.
I'll put up some pics when there on the car...
I bet I get em on with the tinyest of arch work.
I done it on my old 6n with no arch work
Logbook says VW genesis coupe....
That aint no coupe I'd check all the vins match and match the log book before doing anything!
Will do mate, thnx for the heads up.
I thought the breadvans had the round front lights
Mine has these ones
Mine has these ones
Those are MK2 Polos, MK2 and MK2F both had Coupe and Breadvan bodies. As mentioned above check all the VIN numbers and shit, that's not a Genesis nor is it a coupe. By the way you should sign up to Imgur or Photobucket; you're going to run out of storage space real fast using the attachment thing.
Thnx for your help mate.
I'll look over the logbook etc
The only thing thats different from the coupe model is my
Rear arches are square not round....
Do some research ffs.
That right there is your problem
Easily get 9's on a 6n.
people struggle to get 6's and 7's under breadvan arches.
and lol yes, defo check logbook/vin out
...The only thing thats different from the coupe model is my
The roof skin is longer
The gutter trims are longer
The tailgate is different
The rear lights are different
The rear bumper is different
The rear quarter glass is different
The interior quarter cards are different
The parcel shelf is different
The parcel shelf supports are different
I'll stop there...
Basically everything above the floor pan is different from the B pillars backwards.
This does have Genesis glass, in fairness.
Logbook definitely says polo genesis and all numbers match up.
Gonna put on some 195/45/13's
So I'll have a nice stretched tyre.
Polo Genesis would be a valid model ID, but if it says the body style on the logbook is Coupe, there's something very, very wrong somewhere!
Thnx mate, do yo know What it should it say?
Hatchback
Hatchback
Yep ^hatchback^
Green glass?.... Looks to have been modified at some point in it life that may not be original either...
All of the glass except the windscreen has the registration etched
Onto it, so could be all original?
9.5J on the rear
7J on the fronts
Good luck! my last bready was rolling on 7's with rolled flared and pulled arches and it still wasn't 100%
the only way to fit them is with new arches and good luck finding some square ones haha :lol:
On the other hand... if you pull it off fair play and good luck to you sir!
  • 3 months later...
9.5J's are on and are looking good, arches only required
the smallest amount of rolling.
just gotta lower it a little bit to get them sitting pretty.
any pictures of the coupe with the wheels?
pics?
