Polo 6n2 gti headlights
Question to anyone who fitted gti headlights to non gti polo, just done mine today quite happy with them . The only annoying thing I found is the headlight doesn't fit flush with the side indicator . Tried taking pic to show what I mean
8925B3F4-E051-45C1-AC3E-2F8C1B3E8216-624
Do I need to buy gti side indicators ? Or something else to mod or they are just like that?! ;)
Thanks for reading
  • Replies 17
  • Views 2.2k
Did you drill holes for the ballasts to push back far enough? GTI indicators are no different as far as I know
Drill holes?!
I removed like 40 square inches of slam panel to get them in. :lol:
Drill holes?!
Haha so did I
Are the tabs broken on your indicators?
I knew what I meant :lol:
Yeah, they're a shit design.
They honestly shit themselves when you look at them.
Indicator still holds fine, so meh.
Yeah cut off half of slam panel lol !
The holes to attach headlights match up perfectly so no issues on fitment. Just the way they look is a bit odd:)
Another pic for a closer look
EFF6496E-737C-4874-AB4E-D44B26800860-624
Just wanted to make sure there is nothing I done wrong :)?!
Looks like the tabs on the indicators went missing. Try taking them off and refitting,should line up
Had a look at the side indicators, you were right the somebody broke tabs :( are they expensive from steelers you know?
I have a gti and mine sit like that as well what tabs on the indercators are you on about?
These are the clips that go at the back of the indicators. If you don't know how to take the indicators off then the only way I guess to brake the clips:) I think someone else broke mine:(
Correct me if I'm wrong
with mine u twist and pull a bit of plastic between the indercator and headlight then slide the indicator out there are clips on the side next to the headlight but that's it
Same here, but who ever worked on the car before didn't know and broke it:( need to replace it
oh right mines in tack so dunno why is like it then
Heh polo, don't you love them :)
sorted my lights out today they needed adjusting that's why I had a gap like that on mine
What exactly did you do ?
Thx
the beam on the drivers side which was my one like that was about 4/5 inches lower so adjusted it with the white adjusters but one of mine was broke so took the light out and turned it with some grips think I turned it clockwise if your looking at the back of the light and anticlockwise with the top adjuster just make sure your close to a wall or something to keep then level
