Trim piece
Can someone do me a favour and have a look in their polo 6n2 if there is a plastic piece that gets attached to bottom of headlight switch pic below
424F87DD-E613-44BB-A519-C1DA5A1888D6-635
1D11D303-11AA-43B4-9C76-F8F9155987DA-635
Am I missing something or its normal ?!
Right this may not make sense but basically the screw hole you can see needs to be behind the the tab/dash hole bit behind it that you can just about see then there should be a screw to hold it in and stop it rattling
Surprisingly it doesn't rattle :) but basically just need to screw the bit outside on the inside and that's it ?
There is a trim panel missing #2 in the picture
Can't locate it in the parts listing though??
Aha I knew there was something do you think vw will be able to find it ?
Will someone will polo be able to unscrew it and see the item number ?? Please :)
They should be able to, print the picture off and take it with you. I've looked on vagcat.com and an online etka but can't see it.
Cool thanks mate
