heated seats 9n polo
I've just brought some audi tt full leather seats really cheap :-D and I've being told that they can also be heated just wondering if anyone would know what it would take to get them heated? thanks joe :-)
  • Views 1.9k
Guessing theres some sort of loom attached to the bottom of the seats, do the seats have airbags in them? because if not i guess the only wires that will be going into them is a positive and negative for the heating element. If I'm right then i reckon all you'd need to do is take a wire back into the dash somewhere you can get a constant 12v (maybe somewhere near the fuse box so you can have it fused as well)
Then install a switch somewhere maybe use one of the blanks above the stereo to allow you to switch them on and off.
BTW thats just me making assumptions, but i cant imagine its that hard to do :)
yeah they're is a loom at the bottom off the seats and yeah i guess they would but either way i can sort the air bags :) and thanks man much aprricated :) yeah off to the scrappy this weekend
No worries, make sure you don't put power down the wrong wires then, you don't want the airbags going off ;)
Also, if you can't find the proper dash switches ( I couldn't, not for a reasonable price anyway) thenyou can always use a generic round rockr switch and fit them to the plastic trim of the seats. I think this is a good idea because anything other then the oe switches look gash especially on a visible part of the dash. Then you would only need a fuse live, preferably a ignition live as they would drain the battery quickly. And ground the elements to the seat frame.
Do tt seats fit straight into a 9n?
Nah they don't unfortunately, I'm not sure what exactly needs to be done to make the rails fit.
