6n2 zenon headlights
Hi, I have a pair of gti zenons, however the clips that the motor clips into are broken. Does anyone know anywhere you can get replacement clips from ?
Matt
there is someone on here making metal ones not sure who though just have a look or search
I've spoke to him, however hes not 100% if there actaully gunna be made
VW
I heard that they didn't do them
People told me that about window switches but they're cheaper from VW then you can get them second hand off eBay
Always worth a try... Worst they can say is no
Very true, Vw should be the first place you ask that way you know the price and can judge if the second hand prices are right, or require ky jelly :)
Personally, what I do is take the stepper out and wrap ptfe tape around it (the stuff you would use on plumbing joints) then get some hot glue and plop a load onto the ball then shove it in. Then once it's fitted hold the reflectoer bowl through one of the bulb holes until the glue has cured.you can always put nore on if it doesn't look right.
The purpose of the tape is so it has a little bit of movement because it doesn't just move in and out but also side to side and up and down, hence a ball socket. They first one of these I've done is still holding strong after five years.
