removing mk2 polo bulkhead
I'm just considering removing the bulkhead in my mk2 to open the engine bay up for future plans and I'm wondering if removing the bulk head causes any problems ?
and what would be the best way to go about removing it ?
pictures would be great
cheers
  • Replies 15
  • Views 1.5k
Bulkhead? Your car will fall apart when you drive it! You mean the bit of thin metal between the bay and the scuttle?
Yes that's the section I'm talking about I believe a few people have done this before but I'm wondering if there is any problems that it cause
fumes into the cabin /heater intake
you say that, but in the week I've been driving about with it its been fine.
Would u recommend fitting a brace bar?
id reccomend not doing it at all.
its a pain in the ass
That being so I'm not one for shying away from a hard job and I want the space for future plans
So do you loose any rigidity once its been removed
nah i wouldnt think so. when you take it out youll realise how flimsy it is lol
Great, what's the best way would u say to go about doing it?
gas axe
Put a tow rope through one of the holes in it for a wiring harness, attach the other end to a tree, and reverse. Fast.
no harris - gas axe! you just have to grind the edges back then. + you can leave you fuel lines still attached.
i actually used a pair of tin snips and a grinder, along with about 4miles of welding wire pmsl
Speaking to Vic about his Mark1 that's had the scuttle divider deleted he says his bonnet wobbles about a little bit towards the back as you're relying on the hinges to take all the weight on that end whilst the bonnet is closed. Other than whats been mentioned regarding possible fumes entering the heating system, that's not a lot else that's really affected.
dont know about the mk2 but the mk1 bonnet is very weak around the sides compared my mk3 bonnet and I've never noticed any bonnet wobble
Dont rush the paint or itl look shit like mine
