Rear arch trim MK2 Polo
Just purchased a new arch trim (the little stone protector) for my passenger side rear arch.
There's 3 holes in the body that it fits in to but...
Are there little brackets that go in the holes and then the trim clips into them?
Waited 2 weeks for the part and now I cant fit it :( Don't fancy been out in the rain with 3 nice holes in my body work!
Take one of the tailgate badges off, by getting some thin plastic under there and pulling it gently. The plastic from the side panel of a plastic bottle will do it. Or use a knife being careful of the paint.
The badge will pull away easily.
You'll find they clip on the same way. In the holes is a plastic mounting grub, a top hat design made of polypropylene. You need three of these for your arch trim. If you can't buy them new then you can reuse ones from a car in the breakers, good luck finding one though.
Try the 'cars breaking' section.
Cheers mikey! I pulled mine off last year to clean the car (yes clean freak EXTREME haha) and then look back regretfully at the mess i'd just made of my car, especially when te passenger side was my 'good side' god dammit!
Ahh tps will probs order me some in! :)
Can't be more then 10p each from Vw. They surely have them as they use them across the range.
