9N 1.4 Tdi 17965 code help
Hi,
My polo is cutting the boost under a period of load.
If you turn the car off and on again - the problem resets until the next period of load.
Iv had the car plugged in to the diagnostics and this is what it said:
17965 charge pressure control positive deviation p1557 intermittant.
Can anyone help with the remedy of the problem?
  • Replies 10
  • Views 10.3k
From Autodata as it's not listed in Elsawin :? Turbo pressure- control limit exceeded Causes:- Hose connection interchanged/not connected.
Check the charge sense lines for any splits/cracks especially the one going to the N75 valve
AMFChargepressureconnections_zpsa2887f1c
Charge pressure control hose routing diagram
1 - Variable intake manifold flap change-over valve -N239-
2 - Exhaust gas recirculation valve -N18-
3 - Charge pressure control solenoid valve -N75-
4 - Connector
5 - To brake servo.
6 - Non-return valve
7 - Vacuum unit For charge pressure control.
8 - Turbocharger
9 - Charge air cooler
10 - Intake manifold
11 - Tandem pump For fuel and vacuum supply. Must not be taken apart
12 - Cylinder head
13 - Vacuum unit for intake manifold change-over
14 - Exhaust gas recirculation valve Component of the intake connecting pipe Can only be renewed together with intake connecting pipe
15 - Air mass meter -G70-
Thanks for that, where is the n75 valve on one of these? All I can seem to see is a big black box on the top of the drivers strut with about 6 small lines going to it in one block. Cheers
My golf has the same symptoms apart from
It's charge pressure negative deviation or something.
Check for air leaks, and vacuum hoses.
I cant locate that as per the illustration above.
This is where all my vaccums run:
Iv had a good look for leaks from the vaccum pipes but nothing obvious.
Its geeting frustrating now!
18 - Banjo bolt, 15 Nm
19 - Seal Renew.
20 - Hose To charge pressure control solenoid valve -N75-.
So the remedy is to replave the seal behind the banjo?
Thankyou so much so far nige.
The picture gives you the starting point of the pressure sensing pipe for you to follow back to the N75 valve, the banjo bolt and the seals might need tightning/replacing
No problem. I take it that Vac line goes to the black box I posted a picture of does it?
Not sure, but it probably goes in that general direction???
