Projector headlights
The standard headlights on my 2000 polo are dirty on the insides of the glass, and the chromed parts are dusty and not as shiny as they could be.
I've seen the topics on heating and removing the glass which seems OK but how do you re-seal them once the glue has been peeled off? As I don't want them to look tinkered with afterwards am considering replacement options.
Standard types for about £80 a pair or projector angel eye types for £100 a pair.
Are the projector types (FK Lighting) actually any good and do they have proper glass or plastic lenses, or are the standard reflector types best?
I mean best as in best light output not just how they look.
  • Replies 8
  • Views 852
When I "depo-ed" y 6n headlights I used clear bathroom sealant, you would never have know they'd ever been off if I had just cleaned them.
Just make sure you clean all the old glue off or it may not seal properly and leak.
As for angel eyes just make sure you don't get caught out like I did... They failed MOT,turned out to be LHD lights and the seller claimed he never knew
When I split mine for spraying, I used exactly what Matt said, clear bathroom sealant. Worked really well! When I first put them in (winter) I had a bit of moisture, but now I don't have any at all! Must have just been the temperature change of my lovely warm house, and the freezing UK weather
Thanks I might try the heat removal first.
The FK angel eyes have a switch which alters the beam from LH to RH dip plus they are new from a local parts shop so will be seen and double checked before buying.
Moisture is a problem when you take sealed lights from a warm indoors to outside. THe work around is to leave them outside with the bulbs out for a few hours, they stay dry afterwards.
You cannot heat-remove plastic lenses.
Remove headlamp, fill with soapy water, shake the hell out of it, rinse it out. Dry in the airing cupboard overnight.
If the lenses have yellowed, that is degradation due to UV damage, and the only option is a new lens.
Sometimes you can wet sand and machine polish the yellowing out. Depending on how bad it is.
They aren't yellowed, just look dirty as if someone has pressure washed the engine bay with the rear lamp covers removed so dirty water splashes have got in. I think the lenses are glass and I did wonder about just removing the lights and washing them out with clean water and drying out with a hair dryer. Might give it a try at weekend if the weathers decent.
Tap the lens with a tea spoon. I thought all 6n2 were plastic, I could be corrected..
i'm pretty certain they are plastic.
