Adapters 5 to 4 holes
Hi all,
I'm looking to get some adopters for my 6n2. I bought some wheels which are 5 holes, found the adopters I need but am stuck on the info.
This is what I've found http://www.concept-wheels.be/products/ADAP...TO-5-HOLES.html
What's the size of the centerhole? And the centrehole wheel size?
Is this a standard size for all 6n2?
Hope I dont sound sound too stupid
Edited by onyx
  • Views 933
Centre bore on vw's is 57.1mm
Your wheels may be different depending what wheels they are.
6n2 is 4x100
Again your wheels as they are 5 stud stud may be many different sizes (5x100, 5x108 etc etc) there may be markings on the wheels stating what it is.
If not put some pictures up here of what they are, and we'll try help you out
Hi luckily the wheels I've bought are 5 x 100. So no problem there.
Thanks for the centre bore measurements. What's confusing me is the centrehole wheel size? What's this?
The size of the centre hole on the wheel (sometimes covered by a centre cap/trim cover) you need to measure it if you don't know then that's it
If they're VW wheels, the centrebore is still 57.1mm. Wether they are 4x100 or 5x100.
