Rubber door trim
Hi, the rubber bump strip on one side of my Mk2 has come away, it looks like it was glued on. What adhesive should I use to put it back? And is there an easy way of cleaning the old hardened gunk off (short of taking sandpaper it!)? Cheers!
  • Views 830
Tiger seal is perfect for bonding body trims back on. To get the old stuff off you want a 'toffee wheel' in a drill which is a rubbery toffee coloured disc.
Got mine off eBay.
