My Polo
Hello to all, is it possible to search somewhere to find out the info for my polo i.e engine type carb etc. Ihave no books with this car but keep seeing stuff as 6N engine and so on. I am currently looking for the correct Haynes manual btw.
  • Replies 19
  • Views 1.5k
Your model i believe is the 6K chassis being the saloon.
What engine has it got?
8,388,607 post?! There's no way that's legit.
Why not? I've been on here ages in one guise or another.... just all my posts added together!
I would edit it to 0 but I can't :lol:
Back on topic.
Back on topic.
Geez! Yes sir. Well it's definitely not going to have carbs and is probably going to have a 1.4 or 1.6 aee engine
The engine is 1.6 petrol, have been told to get new plugs but even putting in vin number on some sites is not giving me info...help
Reg plate. Is your best bet.
If I was near my laptop id check AutoData for the plug info
Edit:
NGK BPR6EIX
Plug gap is 0.8mm
AutoData should give the BOSCH plug number too.
Autodata gives 9 engine codes possibly fitted!
Have a look in the boot area for a paper sticker, it will give the engine, gearbox, paint codes, on the log book the engine serial number should start with three letters or phone your local stealership with the reg number and they should be able to tell you
1.6 AEE Nige
In that case
Autodata only shows NGK BUR6ET 0.8mm gap
Thanks for the answers so far guys, the number I got from the engine bay last night was...... WVW ZZZ6KZXR 556435. Hope this helps in some way. :?
Finally got my log book today, the engine number is ALM023873. I take it I need the first three letters ta find the plugs I need. Will search now am off shift so I can replace before back at work... cannot however find out if its 8v or 16v engine.
Spark plugs NGK BUR6ET 0.8mm gap from Autodata and see my previous post for the alternatives and torque figures
It's an 8v engine :thumbsup:
:-o Cheers Nige.
Fitted new plugs today but no difference to problem, will have to try temp sender unit as mentioned somewhere else on here.....
Been told that car stinks of petrol when being followed on cold start, have as stated before changed the plugs but need to know why over fuelling when cold. Any ideas please as costing a fortune in petrol.......?
I could be wrong but I'm sure this is to do with you're temp sender, if its not getting the correct reading then it will be sending an incorrect amount of fuel to the engine which would result in you're petrol smell on cold starts.
As above, I'm no expert so you should probably wait for other replies also.
Dante
Thanks for answering Dante, I think it maybe the temp sensor but don't know where to get one from. Eurocarparts not in stock...
