where is the fuse box
new owner of a 93 polo fox.
can't find anything that looks like a standard fuse box in any place obvious. is it concealed?
  • Replies 9
  • Views 3.9k
Look in the glove box bro , or under the passanger seat he he
its in the engine bay.. youve got one ffs how can you not know it isnt in the glove box?!
Under the bonnet, passenger side on the bulkhead
Put simply for you:
1. LIFT BONNET
2. LOOK TOP RIGHT
3. REMOVE PLASTIC CASING
4. CONGRATULATIONS YOU'VE FOUND FUSES
completely dismissed this thing. does not look how i thought it would look.
Edited by Okeefenokee
thank you
Called a continental fuse
ok i took all of the fuses out and tried every slot with a known good one. didn't fix my problem, but i learned a little bit. counting from the top left, 1 lights the switches under the radio, 3 and 4 are the headlights and somewhere around 6 on the bottom row is the dome light. all of my dashboard lights are out, but i guess its a dead bulb. anyone know where i can find a diagram for this fuse pattern. google isn't helping me.
nevermind, got one.
