MK2F heating
I'm pretty new to the Polo, and having like 10cars behind me... could get confused with the Polo's heater.
I had to check the heating after I bought it, as it always blew hot. The temp control's hot/cold selector was broken. I got a used one, changed it, attached the cable to both ends... the temp selector is working fine...
... but how the heating works or how should it? :-D I feel a bit stupid, but...
The vents below the speakers always blow hot... should they?
The face vents below them always blow cold... I read it supposed to, so that's OK.
How the screen/ feet/ face vents selector works? Any use of the heat selector? :-D
If on windscreen... the vents below the speakers blow hot... independent from the heat selector cold or hot.
If on face vents... the vents below the speakers are closed.
Someone please clear these up!
Thanks a lot!
  • Views 2.2k
as far as i was aware they should all blow at the same temperature as selected on the centre console control, not 100% but having driven the same type of polo as you i have never noticed it blowing different temps.
Everything should blow set temp apart from the vents you can adjust, these are "fresh air" where the fan speed effects them the temperature will be outsides air I believe.
The feet setting is temperature adjustable. This is the setting if you want it to get really hot inside the car. (and if you want to burn your legs)
The screen setting is temperature adjustable. In this setting, the small vents below the speakers are designed to direct air to the quater windows to help demist them/stop them misting up. I don't know if they still work in the other settings or not. I never thought about it.
On the off setting, the air is directed to the face vents only, which makes them feel more powerful than when they are used in conjuction with the other settings. These always should stay cold. Good in summer!
I generally leave mine set to the screen setting and adjust the temperature control to suit. Unless it's a hot day where I set it to off, open the fresh air vents and turn on the fan!
Thanks! I'll check the heater control valve...
learn something new everyday, thinking about it, i have only ever used the adjustable ones for cold air, if i want hot air i'd just naturally have it pointed at the screen or feet if they're freezing off. will test this now.
  • 1 year later...
I have the same problem in my G40.
I took the heater control valve off yesterday and even in the closed (cold) position you could still blow through it, all be it restricted.
Does this sound right or has this part worn and I need a new one?
Any advice would be appreciated.
Craig
